Looking good !
Where did you get that intercooler ?
Jim @ turbohorsepower
Looking good !
Don't. Get an SCT BA5000....and use a mafia.
The 13 degrees of timing is probably why you're only seeing 2700 rpm. Try adding about six or seven degrees down low (then take it out above 3500 or so if you need) and that should allow the converter to "see" more torque on the foot brake thus stalling higher.09Stroker said:With the MAF signal being the way it is we stopped the runs short at 5000 rpm. The last pull we made on a mustang dyno it made 670rwhp/850rwtq uncorrected @ 14psi w/ 13degrees of timing with 70deg IAT's throughout the run.
Next issue is the stall on my converter, its supposed to stall at 3500 but is only stalling around 2700 which gives me about 4psi. After the first snow I will pull it and send it off to be restalled.
this is almost identical to my build
