US-1
Banned
Where did you see an exclamation point? You sure that isn't an "i"?????
He's never going to fix it with us giving him all this crap over it.
Doug has said he has seen this with three other cars and could never figure it out. they all pulled the cams. I really hate to do that, but with what you said make some sense, what it the average price for custom grinds? can they regrind the Comp cams to save some money? any ideas?
with the Poor economy and all....
Very simple...
Take the cams out of the car and put the stockers back in there for now. Believe me, I've taken more brand new parts off my car than I can count and just part of the learning process.
I do not subscribe to these miracle cam off the shelf gains. I personally believe that the cam is just part of the larger picture of the motor in general and needs to be a synchronized part of the motor taking into account every aspect of the powerplant.
Your case is a perfect example of this. With you being on the stock auto, those are terrible cams for you as they are set-up in the powerband outside of your set-up. To the contrary, you want a cam that hits the hardest in the lower rpm range and then tapers off with rpm. Looking at your dyno - it's easy to see why you are losing ET.
You should send your first dyno (before cams) to someone who sells/makes cams that you believe in and tell them you have an auto and that you want to go as fast as possible with new cams and not just make a bigger peak HP dyno number. Ask what grind they recommend to make your set-up run faster and optimize it. Betcha' they will not recommend the cams you have now.
Not that this pertains to you but another pet peeve of mine is the NSR cams - to me it is an oxymoron especially considering the cam is one piece of the mechanics of your heads and valve train. To think adding one 'nice' piece in the machine and that is going to make the 'machine' work better is silly - especially considering all of the moving parts in the valve train.
So based on what you say here, can you speculate on what setup the Comp 127200 NSR cams would be good for? Watching Scott go through everything he has with these cams has made me wary on cams for the 3v.
Personally, I don't think any of the 'NSR' cams are worth a shit cause I truly believe you need other parts (like a spring) to go a long with the cam to compliment it.
But, based on your question, I would think the cams would better for a manual car with a FI set-up like a TS or nitrous that builds power quickly. I wouldn't put them on an NA car or a centrifugal or large turbo car.
is not cam problems you need to retune the car...
i wich i can show you what i want you to do you need to know a little tuning software i learned a little with CMR because that's waht i have... if you have DS tuner send me the tune (for this kind N/A applications) i'll cam make the changes and you can try it...
Thanks,
99.9 % of the people that run the 127200 Cams love them and gain in 1/4 mile times. I personally care about the ET's not Dyno numbers.
I have spent a ton (4 figures) on tunes and non worked. I am stuck, really don't want to pay for another tune unless I know it will work. I thought I had a deal with a tuner here but I have not heard from them so I guess they too do not want to take this issue on.
all the tuners I have paid already have given up, even the local dyno tuner. is it a busy time of year, with holidays and people on vacation? I do not know. I am willing to give anyone a try, but in january if it is not fixed I am going back to stock cams.
I would be willing to help you out with it, If i cant fix it then you wont have to pay me for anything. You can pm me here if you want or send a email to [email protected]
Mike Rousch
I am sorry, I did not understand your request,
(Lo siento, yo no entendía su petición)
I speak Spanglish. Aleborjas is saying that your NSR comp cam is not the problem, its your tune. He's willing to explain the fix, but you need to know a little about tuning software, etc. However, if you're using the Diablo Sport (DS) tuner, you can email him your DS tune file for him to review and update it since its a N/A application, so you can try it and see if it remedies your situation.
BTW know of any good Cuban Resturants in the Northern Virginia Area????
Mike Rousch
That is a hell of a deal!
Thank you jejejeje
talk to LITO he will help you with you X3 he knows what i'm telling you
Who is Lito?
Thanks,
