that isn't necessary when following fords procedure with their special tools...
Did you run the low 12s more than one night? I have seen times off here in bristol before is why I ask. The high 12s fit you mods and I cant really see low 12s with just your mods before cams. I could be wrong but I see no way to lose that much MPH and ET from a NSR cam. Gotta be something else if you have run those low 12s on more than one occasion! Terry5357 is running 4.10s and your cams 12.50s Auto car but im sure you know that already, just thinking he picked up .2 off them. Good luck man dont give up on them yet!
were they locked out to be fully retarded or advanced?Since the Chain was Wedged and the Cam Phaser Gear was not removed the CAMS only go in one way so I can't see Degreeing the Cams being the Issue since it's not needed.
I had the TCI Converter redone by TCI before in put in the new transmission this summer.
The way your car is acting there can only be one answer. Your cam timing is retarded. More than likely a tooth off. I have installed several of those cams in these cars with nothing but improvements. Your description of what is happening is a result of late cam timing, which will push the power band up in the engine causing a severe loss in the lower end. If you have the ability to degree your motor I would suggest it.
Were the cams degreed properly?
Very simple...
Take the cams out of the car and put the stockers back in there for now. Believe me, I've taken more brand new parts off my car than I can count and just part of the learning process.
I do not subscribe to these miracle cam off the shelf gains. I personally believe that the cam is just part of the larger picture of the motor in general and needs to be a synchronized part of the motor taking into account every aspect of the powerplant.
Your case is a perfect example of this. With you being on the stock auto, those are terrible cams for you as they are set-up in the powerband outside of your set-up. To the contrary, you want a cam that hits the hardest in the lower rpm range and then tapers off with rpm. Looking at your dyno - it's easy to see why you are losing ET.
You should send your first dyno (before cams) to someone who sells/makes cams that you believe in and tell them you have an auto and that you want to go as fast as possible with new cams and not just make a bigger peak HP dyno number. Ask what grind they recommend to make your set-up run faster and optimize it. Betcha' they will not recommend the cams you have now.
Not that this pertains to you but another pet peeve of mine is the NSR cams - to me it is an oxymoron especially considering the cam is one piece of the mechanics of your heads and valve train. To think adding one 'nice' piece in the machine and that is going to make the 'machine' work better is silly - especially considering all of the moving parts in the valve train.
Trust me, when modular cams are 'off' - it's never a 'couple' degrees. It's 99.9% off 180º and the car would be running on 4 cylinders and his results would have been much worse et wise than they were. I don't think this is the case. I really think he has a crappy cam profile for his set-up....period.
your problem is NOT timing you have more than enough over 30´s degrees as soon you step on the gas i had the same exact problem with the same cams the car was a crap down low you need to retune the VCT tune the cams like if you have limiters and put the desire retard limit and the other parameters that control the VCT 80% load and up on 0 up to 5500 RPM's then retard the cams to 12° thats the way i did the car on the low end fast! even fastest then the stock cams i tried lot of stuff on the track... and the shift point raise it up to 6400 rpm's...
Hey, I saw one exclamation point and two "dot dot dots". What do you want?While this sounds like an idea I just have to ask one thing.....could you please punctuate this post so we have some idea of what the fuck you're recommending? Seriously....I am interested in your answer.
