Project Kama Kaase (Ka-zee)
ZmanM3
The Evil One
Jackson, NJ
This is one sweet build you have going. I'm going to follow it closely. I bet I learn a tone from it.
habu
Way to go Paul :clap:I've always loved the 385 series motor and seeing another one go into a S197, much less a local one is just fucking cool. I cannot wait to watch this thread and see the car run personally.
Slight aside, I've been looking to put a 385 in a older f250 and been over at 460ford.com a bunch lately lurking, the P51 heads are awesome. This is going to be a monster you're building.
psfracer
billy badass
Valencia, CA
DAY 1
Easy day today, just took off the easy stuff
Removed headers and exhaust
Removed the CAI, the radiator, fan, water pump, alternator, pulleys, harmonic balancer, tensioner, power steering, a/c delete
Took off the door mirrors, replaced with block offs.
Should be getting my modified bogarts from Rich at Bogart racing this Monday. I had the 1 inch spacer removed, now that I have strange race brakes. This will make the front tires sit under the fenderwell where their supposed to be.
Next up, will remove the transmission tomorrow
psfracer
billy badass
Valencia, CA
Good link, I remember seeing that a couple years ago. Its actually very impressive when you realize WHEN they were doing that.
psfracer
billy badass
Valencia, CA
And an 1150 won't be enough. Call ProSystems and get a real carb.
I was looking at a couple CFM calculators, most were saying around 1100 cfm with a 545 @ 7500 rpm assuming 85 % VE. Should I be looking for 1300 cfm?
white05gt
Illinois
I agree with SD, I would call prosystems and discuss your plans with them.
firestang70
SW Ohio Ninja
Paul disappointed in a way to see this. I use you as a benchmark as I continue to get my Gen I Whipple running faster here and there. Hope to continue to lean on you for future pointers. On the other hand this looks like a cool project and can't wait to see some vid from the track. Good luck.
psfracer
billy badass
Valencia, CA
Yeah, the GEN I was absolutely done at 20 psi (2.625 upper, 10 percent overdrive lower, stock heads, cams). I was already above the maximum blower speed. I am sure I could have broken into the high 9s if I was willing to spend $4K on heads, cams, retune, but in the end I didn't want to spend $4K for a 3/10ths-4/10ths of a second.
Simon
I was readng through the first post and became interested. I have a 460 block that currently geting magnufluxed and hot tanked for a new build. Although mine will be more of a street/strip combo, going into a Fairlane Super Sport or a mid 80-s Fox.
I was looking at the P-51 heads also. Mine won't be a race car only so I will not be using a domintaor carb or a mechanical cam. We will be somewhere in the 600 rwhp place stroked to around the 545 ci mark. This moor is alrady 30 over, so I will not be boring it out anytime soon.
Looking forward to the entire build.
06vistabluegt
Very cool thread. I've been thinking about something similar for a while now. I keep going back and forth between a BBF and a high winding SBF. That is why i went with the TH350 instead of a 4r trans when i did the auto conversion. Price was a factor as well. Call MArco Abruzzi when you are ready for a trans. He can help you decide btween PG, 350 or 400. He is very well known in the industry.
www.Abruzziracing.com
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Come on Paully... admit it. What you really want is dual quads! :thumb:
psfracer
billy badass
Valencia, CA
Umm, yeah! But I think that would really be overkill. By the way, I have my car up on 4 jack stands, took the power steering stuff off, now going to start on the transmission.
I need your lift---would you install that thing already?
ZmanM3
The Evil One
Jackson, NJ
How much weight did you save on the mirrors? Think not having them will help any with drag?
psfracer
billy badass
Valencia, CA
I guess they would create drag at 150 mph, but I just did it because I hate the stock elephant ears. I weighed them for laughs, 4.5 lbs for both.
Judaspriess
Hawaii
Subscribing.
I will be in San Diego next month and going to Pomona for the NHRA (12-14th), could I stop by to check it out?
psfracer
billy badass
Valencia, CA
Yes your welcome to. PM me and I will give you my address. I live about 45-1hr away from the track.
