Mystickeith50
There's a new block for 2013, I wonder if that's being addressed. Considering the Cobra Jets will be using those blocks, I'd think they would want them as strong as possible.
THOSE BASTARDS!!!!!! lolol
Then how do you explain an engine where the plugs, bearings, pistons were good but the cylinder bore had cracks? I have a real hard time believing that is a result of a "toon" I would think other parts of the engine would fail long before the cylinder wall would.
I think its a fact that the coyote block is not as strong as the 3V block.
That doesnt sound like a broken sleeve at all, that sounds like cylinder taper...As I recall the sleeve didn't break, it was pushed out and became out of tolerance so to speak.
This is a 5.0 block, the red arrow shows where there is no supporting material that was on the 4.6 block.
No, 2012 Cobra jet's were still the aluminum 5.4L. 2013 is the first Cobra Jet to get the supercharged 5.0L.Didn't 2012 Cobra Jet's have blowers and use the original coyote block?
From what I saw and heard the cyl wall did crack, it bowed out/warped.
dooo it. We would love to know... or I know at least I wouldI'd really love to order a 2013 block in to compare, but my boss would probably shoot me. lol.
dooo it. We would love to know... or I know at least I would![]()
as for comparing it to the 400hp 1.6L block from honda? The 1.6L needs to be filled or at least studded to handle it. And no matter what you do they are throw away engines, it wont last long @400hp crank. magic number is 20-23psi on pump gasoline, you need more than 23psi to make 400hp out of the 1.6L engine. Anything over that its going to live a short miserable life.
