Hey man, new here, I just wanted to ask you, why did you engine blow in the first place?
Tune has been exclusively blamed by the people who looked at it. Here are some points.
#1 - The spark tables are not renormalized for higher than 100% load. This is basic stuff. This should be done on any blown car.
#2 - The Torque Table is less than stock. Obviously this is wrong, it should be raised much higher. This is not a novice mistake, as there are alot of people that do not seem to understand drive by wire yet, however, if you don't understand how the table works, then don't mess with it. Obviously don't reduce it less than stock, now that the car makes much more torque than stock.
#3 - Knock Sensor is basically off at WOT. I do this at times, but only on cars that have false knock. A stock car with a Whipple doesn't need this turned off. This alone may have saved your engine.
#4 - Default Load table looks really whacked, IMHO.
#5 - MAF Temperature Compensation is modified. He is surely not smart enough to change this table without lots of data that he doesn't have access to. Most people (me included) zero this out unless the car is stock (N/A)
#6 - The fuel tables are raped. There are alot of "tooners" that do this. The fuel table is where you command what you want the airfuel to be, and if the MAF is dialed in, that is what you get. Some people (like in this tune) commanded stupid airfuel ratios to get a result, for instance this tune is commanding 8.79 AFR at full throttle above 6500 RPM. Obviously this is wrong.
#7 - No fuel pump tuning at all even when the fuel system is totally different in the kit.
#8 - and the one that may be the worst mistake in the tune and a possible cause for damage and also the ingenuity of raping the BFT up top is that the injectors delta pressure was left stock and the FGT stock 38s injectors won't hold up that power levels if you do not raise the pressure. Your Ford provided calibration did this.
My engine lasted just under 1000km's on this tune 850km's of which were driving on the highway home. The whipple tune lasted over 10,000km's without a problem. Made 451 on whipple tune (dynojet) and 417 on engine blowing tune (mustang dyno)
