gijosh28
Bad Penny
As soon as I get my car back from the new motor build and new turbo kit at BBR I will be doing this. I am going to have to run the wires for the buttons though. Thats gonna suck a little.
The cruise buttons are easily wired up, and the buttons all light up like they should. However, I really don't think you'll get the radio controls to work with any part of the factory stereo system in the 05-09.
I can get you one as well if he can't.No they won't work with the factory stereo system, but I am almost positive they will work with the Sony/Pioneers that have optional wired remotes. I need to see if BBR_John can order me this same stering wheel too. (John are you reading this?)
Ok I got it to work, using the existing wire harness from the old wheel and the new one. To make the cruise work ; Black (new harness) to Green (old harness), Red to Red, Brown to blue, grey to white. If you want the lights to work on the radio control Red to red, amd black to green. The lights on the steering wheel are blue not green. Here is a pic.
It looks to be a whole GT500 instrument cluster he swapped in.Where did you get the speedo/tach plate, and how did you switch the two?? Need to do this.
Upper center right...Actual GT500 below:I'm not so sure, don't see the boost gauge. Then again I could be wrong!
Not me, I'm still sporting the stock Shaker 1000.Didn't you make a post somewhere that you went with a '10 navigation system from another vehicle?
