SOOOO I found the leak for sure. I pulled the window weatherstrip first and then took out the screws to the seal retainers and dropped the seal retainers out. (these are the black plastic strips that hold your window weather strip to the body.)..so by lookin at the pictures you guys can see that these seals are SCREWED...they are supposed to be a solid seal, all the way down the retainer against the body...if these seals are bad, water will run behind the retainer, inside the A-pillar and inside the car into the floorboard on both sides. (if both seals are bad). this is a 36K mile car that spent the first part of it's life in Florida. These retainers have never been removed so these seals must have basically baked themselves out inbetween the body and the retainer over time and no one's noticed. Hopefully this will help some of you guys that are looking for leaks. Enjoy the pics! Keep in mind, this should be one solid seal all the way down the retainer. As you can see, neither are worth a shit. Oh and none stuck to the car or anything as I pulled them off. Everything that was there is still sticking to the retainer. Way to go Ford!
