The Offical Jegs 15" Wheel Thread
black05stxjt
Thats 2.5 inches wider than the rim. Thats' some serious bulge, is that ok? Isn't the general rule not to go over 1.5" vs the wheel width?
seen alot of cars doing it for along time.....i think its ok.
black05stxjt
I like it. Personally, I would probably use a smaller tire but it does look good! Thanks for the pictures!
:thumb:
i just needed a 28" tall tire for when im on the spray i come through the lines before at 6800rpm so these will help me out with that....plus i got a smoking deal on them!:clap:
US-1
Banned
The ShadowLands
Depends on how much power you're making and how much air is in the tire during the run. I personally wouldn't do it but........to each his own.
I like to use a wheel that is the same width as the tire. You can get away with running a smaller tire since the footprint spreads out more evenly giving you a wider contact patch. I've even run 12" wheels with a 10.5 slick like the True 10.5 guys do.
black05stxjt
thats correct....but most of the TT5 guys run the 29.5" tall tires....and to be honest, i dont think there is many s197's on this forum that could over power the wheel and tire combo that i have prob plstang and maybe 1 more.
US-1
Banned
The ShadowLands
We did it with a 28" tire as well as the 29.5 tires. Hell....I put a 26 x 8.5 tire on a 10" wheel before just to prove a point. :evil:
xtweakerx
Get SOME!
Palm Beach, FL
Here it is guys.....15x8 with a 28x10.5x15 Stiff Side wall slick
what size is the wheels and tires up front? and did u need to modify or just bolt on? what spacer, lug nuts? studs? etc?
Hitman
Banned
Tennessee
you should start reading at the very beginning of this thread. It says in the first post.
black05stxjt
lol bet it was a little stretched out lol..... need to get with ya the next time you are heading to strictly i need a dyno tune!
cjtenney
Official Vendor
shit! i ordered the 28x11.50-15 ET Streets! After seeing the pics I can already tell that they are going to stick out of the wheel well. Looks like Ill be sending them back for the 10.50s. Only reason I went with 11.50s is because I have 26x11.50-17 ET Streets on my stock bullitt wheels. Guess I should have known better about the "buldge" on a small wheel diameter. You live and ya learn I guess! Paging Jegs return dept!
cjtenney
Official Vendor
wait im confused. Im comparing the tire he has on his car (28x10.50-15 ET DRAG) vs the tires that I ordered (28.11.50-15 ET STREET) and from what I understand, his are wider than mine...how is that or am I reading the stats wrong?
ET DRAG SPECS (28x10.50-15)
10.5'' Tread Width
Tire Compound:M5Tire Overall Diameter:28.1''Average Roll Out/
Circumference:
88''Tire Tread Width:10.0''Tire Section Width:11.7''Wheel Diameter:15''Spec Wheel Width:10''Tire Weight:24.0 lbsSuggested Tube
Part Number:
672-9555
vs. the ones I ordered
ET STREET (28x11.50-15)
8.5'' Tread Width
Tire Compound:M5Tire Overall Diameter:27.6''Average Roll Out/
Circumference:
87''Tire Tread Width:8.6''Tire Section Width:11.1''Wheel Diameter:15''Spec Wheel Width:8''Tire Weight:22.0 lbsSuggested Tube
Part Number:
672-9553
Am I correct that the 11.50 wheel is actually less wide and smaller in diameter than his 10.50 ET DRAG??
cjtenney
Official Vendor
awesome! they should tuck in there nicely then! I was worried cuz my car is lowered!
Red03SVT
Yeah if you wanted an ET Street the same as his you would get a 28x12.50 ET Street
chad05gt
Lake Charles, La
10.5'' Tread Width
Circumference:88''Tire Tread Width:10.0''Tire Section Width:11.7''Wheel Diameter:15''Spec Wheel Width:10''Tire Weight:24.0 lbsSuggested Tube
Part Number:672-9555
8.5'' Tread Width
Circumference:87''Tire Tread Width:8.6''Tire Section Width:11.1''Wheel Diameter:15''Spec Wheel Width:8''Tire Weight:22.0 lbsSuggested Tube
Part Number:672-9553
I got something in the middle...
3758 - Mickey Thompson ET Street Drag Tires Details
9.0'' Tread Width
Tire Compound:M5Tire Overall Diameter:27.0''Average Roll Out/
Circumference:
85''Tire Tread Width:8.9''Tire Section Width:10.6''Wheel Diameter:15''Spec Wheel Width:8''Tire Weight:22.0 lbs
US-1
Banned
The ShadowLands
9.0'' Tread Width
Circumference:85''Tire Tread Width:8.9''Tire Section Width:10.6''Wheel Diameter:15''Spec Wheel Width:8''Tire Weight:22.0 lbs
So.....what do they look like on the car, Slick?
