Ya, it is the Steeda 10 rib Belt drive. Looks pretty mean! Supposed to push 11-13psi for now.
wow. ive been looking for a build like this... THANK YOU!
btw. i always thought that the aluminator was a 4v dohc long block. or is it available either way?
That looks awesome man, very cool! Will you be able to drop the motor like that or will you need to remove the manifolds?
Thanks!
Ran into another small problem. Need two more flywheel bolts. Haha another three days down. Man it always seems to be the small stuff that gets you!
Strange I can not edit my first post...
Quick question. Guys think 60lb injectors dual fuel pumps are good for up to 600whp? My immediate goals are around 520whp. Should I get the KB dual BAP?
Important question:
Do you guys think my Whipple tune (procal) will work with my new setup? The only thing that is really changing is the lower compression, heads, and 6 speed haha. And by work I mean idle and/or drive it from the shop to my house. Or should I not even attempt to start it? (injectors, fuel pump, blower, gears are all the same still)
Haha can someone answer this question for me?!
Important question:
i dont think so. i think that compression will make a huge difference in required tune. im sure your shop will send you a temporary tune if you assure them that they will be dynotuning in the next few hours/days.
By shop I mean an Audio shop that I used to work at. There are no dynos for 450kms (281.5miles) from here. Shop is a good 10km's from my house. (6.25miles) [I Americanized it for you guys]
