That looks killer Rick!!! Just killer.....
How streetable is the 323" big bore kit?
That's exactly the engine I want in my car!
Do you have to use stage III heads or would stage II heads work fine? What kind of cams would you have to use. Probably be useless to put nsr cams, huh.
AWESOME Setup and WOW no power adder = weird for such a BADASS Motor but ehh to each there own.
Will the stock hood shut? Im interested in seeing how much extra flow it will add with a blower and meth. Any results with that yet? My motor is pretty much the same as your but its a 302 stroker and stock cams.
Thanks
The stock hood will shut, the last photo I posted shows it under the factory strut tower brace, so there is more than enough clearance.
This is the first one we received, so we haven't done any testing with them yet.
-Rick
It should be totally streetable, I wouldn't hesitate to put it in a daily driven street car.
-Rick
has the compression ration question been answered? curious to know myself...nice set-up
Rick, how do the ports on the intake match to your stage III heads? Did you port match the intake?
Dan
no upgrades needed for cooling?
verry VERRY nice
